I could see that. The one I have has metal clips and a metal locking channel. Plastic on a tonneau cover is crazy, hopefully there isn’t others ones out there like that.This quote is hidden because you are ignoring this member. Show Quote
E .· ` ' / ·. F
Your tears fuel me
Short antenna so the airport parking garage doesn’t make you lose your mind lol. Tailgate dampener. https://www.cjponyparts.com/ford-tai.../FL3Z99406A10AThis quote is hidden because you are ignoring this member. Show Quote
E .· ` ' / ·. F
Your tears fuel me
I advocate for people to get a decent bug / rock deflector for the leading edge of the hood. Paint doesn't so much pit with impacts, but it chips out in large pieces on the aluminium. Getting some beefy protection on there is a must, and I think the style I got looks pretty good on there.This quote is hidden because you are ignoring this member. Show Quote
Boosted life tip #329
Girlfriends cost money
Turbos cost money
Both make whining noises
Make the smart choice.
Originally posted by Mibz
Chris how does that attach?
E .· ` ' / ·. F
Your tears fuel me
That one comes in 3 pieces with 3M double sided tape.This quote is hidden because you are ignoring this member. Show Quote
Turbos cost money
Ive read some long-distance reviews where people say those 'aeroskin' type spoilers rub against the truck. Any issues so far?This quote is hidden because you are ignoring this member. Show Quote
[/QUOTE]
Love the color.
Did a oil change on the wife’s navigator, didn’t want to wait and do the drop off with ford. Plus they didn’t answer the phone.
Cost me 80ish, but I switched to synthetic.
None, and because the deflector is double sided foam taped right onto the hood, there is zero movement, so that will never happen.This quote is hidden because you are ignoring this member. Show Quote
Turbos cost money
Out of curiosity, did you do just the deflector or with a 3M wrap?
just deflector
Turbos cost money
This quote is hidden because you are ignoring this member. Show QuoteInteresting I went from an Undercover Flex Tri-Fold on my old truck to a Revolver X2 on my new one and I love the revolver. It seems no more or less rigid when driving on the highway with a strong crosswind but does have the added benefit of allowing me to see out of my back window when it's in the fully open position and not leaking water in a car washThis quote is hidden because you are ignoring this member. Show Quote![]()
Lots of our field trucks have these plastic deflectors and most have paint worn off (usually at the far corners) when they are going to the auction.. 200k or 5 years old..This quote is hidden because you are ignoring this member. Show Quote
That is so weird. How is the paint being worn off? The whole thing is stuck on with doublesided tape the whole way around...nothing moves...I am confused as to how it could wear paint off. The standoff style that clips onto the hood, I can understand, but these...?This quote is hidden because you are ignoring this member. Show Quote
Turbos cost money
Usually the plastic wears through the tape and then the deflector can move and then it wears through the paint.This quote is hidden because you are ignoring this member. Show Quote
I am not saying this will happen on a regular everyday daily driven truck but on the field trucks which have heavy rough road usage, they definitely get paint wear from the deflector.
I have the same shape but mines the AVS 1 piece and stuck on with 3M. My hood after 2 years is pretty mint expect 2 small chips but my front bumpers a mess. I was on the fence with getting one of these because ive read reviews of them flying off but never wearing the paint, i only have one now because i got it for xmas.This quote is hidden because you are ignoring this member. Show Quote
Catch can is a must do if you have the 3.5
Same on the 2.7, isn't it?This quote is hidden because you are ignoring this member. Show Quote
I only know the 3.5 so I didn't want to comment that it was a "must have" on the 2.7 as well. Most engines benefit from a catch can setup. I run a Mishimoto which does an amazing job but its pretty small so I have to empty it on almost a daily basis if its cold outside (traps a LOT of water) but in the summer it'll go a week before it fills up. When I say small I mean tiny like smaller than a beer can. Probably 205ml capacity hahaThis quote is hidden because you are ignoring this member. Show Quote
Get rid of the shit factory rubber if you plan to "use" the truck. Still cant believe some of the rubber factory trucks come with. GM is the worst, but even with the Ford's I usually get KO2's or something 10ply similar before I pick it up. Just got my tune installed on the new truck, seems great so far!This quote is hidden because you are ignoring this member. Show Quote
On another note, the deals on the leftover 2019's is crazy! Been hunting for a single cab short box 4x4 with the 5.0 FX4, not very common unfortunately. I suppose with the facelift 2021 coming soon it may get even better if your not too picky on color/options.
Even on the Gen II 3.5 EB's? If they've got GDI and Multi-Port the back of the valves will be washed with fuel which should in theory reduce carbon deposits a fair bit. In my experience catch cans on a winter driven vehicle are a massive PITA and if they freeze up can wreak havoc.This quote is hidden because you are ignoring this member. Show Quote
