Rotors Turned in Calgary? - Beyond.ca - Car Forums
Results 1 to 17 of 17
Thread: Rotors Turned in Calgary?
    Sep 2003
    Calgary // Alberta
    2018 Audi Q5 2.0T - Stage 2 Tuned
    Default Rotors Turned in Calgary?
    I need to get a set of rotors turned, but I called all the places I used to do that (Cdn Tire, Auto Value, PartSource) and no one does it any more?!
    Where are people getting theirs turned?
    Its often cheaper to buy an aftermarket set, than it is to turn OEMs.
    And that is becoming standard practice at many shops as well.
    I used to turn my rotors with a new set of pads till I read this from Wilwood.
    Q: Should rotors be turned before replacing brake pads or after a set amount of road service?
    A: Not if they are still serviceable. In fact, the best way to bed your new pads is with a rotor that has already been bedded. The rotor is basically the radiator for your brake system. The larger the rotor for any given design, the better it cools. Each time you turn a rotor, you remove material; therefore, you remove some of its ability to cool. You should regularly inspect your rotors for conditions such as cracks or excessive wear and immediately replace them if they are defective or out of tolerance. If you have any questions, please contact a Wilwood Sales Technician at 805-388-1188 or email Sales/Tech Support.
    http://www.wilwood.com/TechTip/TechFaqs.aspx#RT
    Obviously this is as long as the rotor is in good shape on the braking surface.
    Then follow the bedding procedure they list on their site. Sometimes difficult to do in the city but it is possible.
    May 2010
    1992 KA-T Silvia
    auto value in midnapore just turned my rotors... not sure where your getting your info.
    cetus automotive will also do it
    Jun 2007
    Toyota 86 Wannabe (FR-S)
    I've had rotors turned before, but if they're in decent shape with no deep features or scoring, then you may as well just slap the new pads on....
    They'll probably look the same anyways after a week of use lol
    Photo by: Kevin Chow
    Rotor Minimum Thickness" limit (expressed in millimeters) engraved on the edge of the brake disc.
    Sep 2003
    Calgary // Alberta
    I have a pretty harsh vibration in a 2013 Odysssey a family member has. I assumed it was the rotors (either pad deposits or warping).
    depends when the vibration is happening. when you're applying the brakes or just straight driving..high speed or low speed
    are wheels balanced?
    as per your original question, dealerships still turn rotors...
    I believe its still cheaper than buying a new set of OEM rotors from the dealer, so its really up to you. aftermarket ones can be just as good, if not better, depending on what you're willing to spend.
    Nov 2011
    On my 5 series BMW, my factory trained BMW mechanic (owns his own shop now) refused to turn the rotors as he said it is not done on BMWs. On my Honda, Hu's installed better than factory (quality and price) rotors rather than turning them as the price was about the same as the turning fee.
    Previously I had rotors turned at the Honda dealer in the NW, after another 10,000 kms they were in need of replacement so turning was wasted money and I should have replaced them just like Hu's advised.
    Exactly because of what I posted before from the Wilwood site. But then again, most people don't heat cycle their brakes during break in.
    Feb 2008
    Applewood, Calgary
    1988 300zxt, 90 jetta
    Yeah, if you're having vibrations during braking, try doing a brake bedding process. It might get rid of the vibrations (deposits left on rotors), if nothing else it should increase braking performance.
    If you take anything I have to say seriously, you're gunna have a bad time.
    1988 300zxt. gt35, stance coils, etc.
    1990 Jetta VR6 Daily, "stock"
    Originally posted by ercchry
    people are dumb, kids need to stop playing in the streets, SW soccer moms are the worst kind of people, the end
    Jan 2006
    GR Supra MT, MK8 Golf R
    Bump
    Any beyond recommended shops for turning rotors? I'm looking to have some two piece rotors turned as I'm changing brake pad compounds to something a little more aggressive and the pad supplier strongly recommended I do so before bedding the new pads.
    Quote Originally Posted by 94boosted View Post
    Bump
    Good bump.
    Would be interested to know if the method some call Blanchard Grinding is available, here.
    Jan 2006
    Ended up having Calgary Autoworks Grind my rotors for me and am quite happy with the result. http://calgaryautoworks.shop/specialty-services
    That's one fine grind!
    Mar 2005
    Pushbroom
    I had that chinaman by the airport do mine, I think it's called McCall brake and muffler or something. They were large 2 piece performance rotors like yours, he did a great job and only charged me $40.
  1. Good place to get rotors turned?
    By blktopbig28 in forum Mechanical
    Latest Threads: 06-22-2009, 10:01 AM
  2. Magnum Cross Drilled Rotors or KVR Cross Drilled Rotors
    By JDM_RS13 in forum Performance Modifications
    Latest Threads: 06-13-2005, 07:51 AM
  3. knocking when idle turned down
    By bub2002 in forum Mechanical
    Latest Threads: 04-01-2004, 07:07 PM
  4. car not been turned in 3 months..how??
    By sarahmicra83 in forum Mechanical
    Latest Threads: 02-24-2004, 12:31 PM
