Today I saved a fellow Rotorhead from suffering what I went through and getting ripped off by what I believe to be a scam artist/ Con artist/ and in general sad and dishonest individual. My goal here is to educate and inform anyone who is considering getting a rebuild from Conroy @ 4 Kruzn. This is what you might get.
For those of you who don't know or haven't seen these are the pictures and story of my fresh engine rebuild from Conroy @ 4 Kruzn.
I paid $3800 plus a core deposit for this rebuild. I gave Conroy a 13B-REW core on top of the $3800 I paid him for a fresh rebuild, or so I thought. Unfortunate circumstances necessitated the replacement of the coolant seals after less than 300 kms. At this point no blame had been laid for the coolant leaking into the rotor chamber. Upon opening the keg with a fellow rotorhead much more knowledgeable than I, what we found inside was truly disgusting. I received a re-built engine with an FC3S E-shaft. The tension on the timing chain (I meant oil pump chain) was out of spec. We found used side seals with gaps to the corner seal less than 0.10mm and in excess of 0.4mm as per Mazda specs. For those of you in the know, to not use new side seals and to not carefully measure them is completely disgusting. If he failed to spend the proper amount of time sizing and shaping the side seals what else had he cut corners on?
The front stationary gear was showing copper. We had specifically discussed the replacement of any bearing that was in need of replacement. Apparently Conroy didn't think this bearing needed replacement. Onto the porting. The porting looked like it had been done by an amateur, decide for yourself. The rotor housings were in poor condition and Conroy had nicked the sealing surface when he was porting them. He told me that this was "no big deal" and that I was being "too picky". If you can't port the housings without nicking the sealing surface take a few minutes and tape them up, seems simple right? Back to the coolant seals. From time to time in the casting process there can be slight imperfections and indentations in the aluminum along the path where the coolant seal sits. Proper procedure is to fill this hole when building the engine. Conroy either failed to see this imperfection or decided not to fill it. As a result the coolant seal bubbled and I started to get coolant in the rotor chamber. This was the reason I had to pull the motor and the true story of the motor began.
I suspect Conroy did not think I would pull the motor at less than 300km's and could get away with not replacing the bearing. As I'm sure many of you can attest dealing with Conroy is a slow and painful process. Before he has your money he is quick and deliberate. Afterwards however he will straight up ignore you and is a complete PITA to deal with. After calling and text messaging Conroy with no response I decided to PM him on RX7 club. The beauty of RX7 club is that you can see when someone has logged on and of course I knew when I had messaged him. He was completely ignoring my PM's. Fantastic customer service!
Months later in a last ditch effort of frustration before I opened up the engine I text Conroy and finally got a reply. Dealing with him was terrible. All he offered me was warranty work on the motor. Why on earth would I want him to touch my motor again after everything that I found. I asked him for monetary compensation but all he offered was to exchange parts. I accepted the replacement parts. I invite Conroy to come here and defend himself, I'd love to see him try and explain his work.
PICTURES
http://s1286.photobucket.com/user/ky...?sort=3&page=1
