Finally upgraded my home wifi to something that works - managed wifi review - Page 50 - Beyond.ca - Car Forums
Page 50 of 51 FirstFirst ... 40 49 50 51 LastLast
Results 981 to 1,000 of 1002
Thread: Finally upgraded my home wifi to something that works - managed wifi review
  1. #981
    Mar 2007
    Edmonton area
    Has wheels
    Running starlink internet but I want to bypass their modem/router.
    Because of installation of the starlink dish, I think I want to use a ceiling mounted router would be best.
    This is completely out of my knowledge base as I typically have used the Telus supplied gear in the past and it served my needs fine.
    House is a bungalow - suggestions?
  2. #982
    06 S2000
    I don't know enough about the starlink stuff to give advice, but I assume since it's a disk, you need to use their modem. You might be able to get a bridged mode?
    Edit: https://kb.protectli.com/kb/starlink...e-bridge-mode/
    My car sounds like shit.
  3. #983
    Oct 2009
    rally pig
    if you are going with the standard starlink dish, you will need to order the additional ethernet adapter (50$ iirc), not sure how it is on the consumer side but you first activate starlink through the included wifi router and mobile app, then there I recall seeing a slider to enable passthrough.
  4. #984
    Mar 2007
    Edmonton area
    Has wheels
    I know you can bypass the starlink router, that's not an issue. Mostly looking for a good recommendation for a ceiling mounted router.
  5. #985
    Mar 2009
    Silverado
    My asus router failed a firmware upgrade, and it has been giving me grief ever since. Today it decided to kill the wifi and only work for hard connections. tried manual updates and hard resets, still cant get it to do anything. Any ideas? Or should I wait until tomorrow and replace it?
    What should I get?
    Thanks and Happy New Year.
  6. #986
    Aug 2011
    Strathmore
    2005 Dirtymax
    Quote Originally Posted by dirtsniffer View Post
    What should I get?
    Check and see if there is a 3rd party firmware like dd or tomato or another variant.
  7. #987
    Merlin firmware
    look, if you stick your dick on my shoulder, then I'm gonna stick my dick on your shoulder. That's how shoulder dicks work.
  8. #988
    Mar 2010
    Ioniq 5
    Yeah I'd try dd-wrt or if not see if you can roll back the router and install a prior firmware on it instead.
  9. #989
    Mar 2009
    Silverado
    Been trying but I can't seem to get it to roll back to factory or to accept any other firmware after one failed. Trying the firmware restoration tool for a second time now. Last thing I can find through their support.
    Managed to get the merlin firmware in place, but now the router won't connect to the internet. Wireless networks still not available. Fml
  10. #990
    Sep 2012
    Try resetting your isp’s modem.
  11. #991
    Mar 2009
    Silverado
    ^Thanks. That got me connected back to the internet, but still no wifi networks
    When I try to enable WPS, it says I need to enable wifi, and when I hit go, it brings me to the enable radio switch
    Name:  turn on wifi.PNG
    But my radios are currently enabled.
    both my networks say they are on channel 0
    I think I need to get off Channel 0, but when I go to select channel, only Auto is available.
    Name:  channel 0 options.PNG
    Couple forum posts are saying it is likely a hardware failure...
  12. #992
    FYL I guess.
  13. #993
    Sep 2005
    Wifi 7 is here, and most of my clients aren't even wifi 6.
    https://www.cnet.com/home/internet/w...means-for-you/
  14. #994
    Oct 2008
    South of Calgary
    is broken
    Eh its diminishing returns. The Features in 7 are not enough to warrant an upgrade.
    802.11ax is fine for most homes and offices.
    A Theoretical maximum of 46 Gbit/s is pretty dope though. Might be enough to sustain a 1G connection at home.
  15. #995
    Quote Originally Posted by jacky4566 View Post
    Considering UniFi completely skipped WiFi 6E in their U6 products, you’d have to go WiFi 7 (U7) to get 6ghz support.
    Price for U7 Pro is actually reasonable.
  16. #996
    Bicycle
    Quote Originally Posted by phreezee View Post
    1st wifi 6 device I got fucked with my wifi 5 router so I got a new AP until Intel fixed their drivers on the laptop. To me wifi only has to work, I don't really care about performance gains on it.
  17. #997
    Feb 2008
    Does anyone have any experience with power line adapters?
    I'm possibly moving in to a new place that has, if I'm lucky, 1 cat5e cable run. I was thinking of taking my Unifi stuff and setting up 2 ap's in the house then using a power line adapter in the office.
  18. #998
    You can sometimes snake a Cat5 cable either down to the basement or up to the attic to get it to the other end of the house. Or I've seen popel go through an exterior wall and run the around the house under the soffit. Lot of options if you want to get creative.
    Unless it's a rental. then Powerline is an option. Or mesh with dedicated backhaul channel may be just as good?
  19. #999
    I think the power line adapter is kindof a last ditch attempt. Maybe even below wireless back haul.
    MOCA would be better and actually works pretty damn well.
  20. #1000
    Sep 2012
    Honestly with the Unifi stuff using powerline is not worth it. Their wireless APs work soooo much better than consumer level shit.
  1. Finally upgraded to a dual band DD-WRT router
    By WhippWhapp in forum Computers, Consoles, and other Electronics
    Latest Threads: 04-04-2017, 10:49 AM
  2. FS: HP Procurve 1800-24G managed network switch
    By Smokem in forum Computer Hardware & Peripherals
    Latest Threads: 03-14-2012, 06:09 PM
  3. Managed Funds
    By cidley69 in forum Real Estate / Finance
    Latest Threads: 02-23-2012, 08:44 AM
  4. Something, something, something, Dark side
    By Tik-Tok in forum Entertainment
    Latest Threads: 12-27-2009, 08:15 PM
  5. FS: Netgear FSM726S L2 managed Switch
    By 02WhiteWs6 in forum Computer Hardware & Peripherals
    Latest Threads: 11-16-2007, 05:03 PM
