Hey guys, I'm trying to wire in a gfci switch after a bathroom reno. In this configuration the bathroom lights and fan work. The lone hot wire capped off is on a seperate wire run with the white wire connected to the 2 light beige wires. If that white wire isn't connected to the 2 beige wires the lights still turn off and on with the switch but the fan doesn't work.
Do I wire in the hot and the white wire onto the bottom of the GFCI and then the 2 blacks and the 2 beige wires onto the load side of the gfci? I'm a little lost on this and any help would be greatly appreciated
edit: The bathroom lights aren't over the bathtub or anything
