TELUS fibre (FTTH) - Page 8 - Beyond.ca - Car Forums
Page 8 of 20 FirstFirst ... 7 8 9 18 ... LastLast
Results 141 to 160 of 388
Thread: TELUS fibre (FTTH)
  1. #141
    I mean does optik suck up some of your bandwidth if you use it?
    No it does not. I pay for 150 and I get 165/165 even when someone is watching tv and the set-top box is recording simultaneously.
  2. #142
    I think that was only an issue when optik was running on copper and the system couldn’t actually handle the extra bandwidth.
    The 10-15 mbps optik takes was a big deal at 50-75mbps copper, not so much at 300+
  3. #143
    Not Aspen
    Two from Freemont
    Yea I have port 1 bridged on my Telus Modem which I run my network off of and port 2 is used for optik.
    Theoretically if I bypassed the ONT into a USG I could do the same thing and run a separate LAN from the USG for optik. But there is some trickery involved to make it work.
    Why? I think I mentioned this before.
    TELUS gave me a dgs-1005g and splits the network right after the modem. My USG connects into the switch and mainlines the IP direct from TELUS. The other port goes to the telus router for Optik (when I had optik). No need to hop through the TELUS router.
  4. #144
    So you jut have a switch on the tower side of the ONT to split the network?
    Can the ONT handle the upstream NAT and DHCP to split this?
  5. #145
    Not Aspen
    Two from Freemont
  6. #146
    Oct 2003
    ute
    I thought the telus modem was just meant to provide wifi? Can't Telus just split the signal after the ONT to optik+LAN?
  7. #147
    I mean that’s effectively what my gateway is doing. Gateway also talks to my wireless optik box.
  8. #148
    Oct 2003
    ute
    Okay, so it sounds like I can connect the Nokia GPON SFP directly into my new UDM Pro, bypassing the ONT and the telus hardware. I can then setup the UDM Pro for multicasting to get the Optik side of things running. I think (???) I can then just plug the Optik PVR into the routers switch (or maybe my main switch) and run ethernet to each of the TV locations to have optik working.
    Question is if I need to use the wireless TV boxes I'm not sure how I would use them? I think Telus supplies you with an AP if you ask, so I guess I would just have another wife floating through the house that is used exclusively by the Telus optik boxes?
  9. #149
    Yup. I have heard it isn’t straight forward though.
    Is your SFP line in the right location?
  10. #150
    Oct 2003
    ute
    They are just doing the community now. So I will get the guys to run the fiber to my initial optimal location
  11. #151
    Cool. Keep my posted as I’m interested in doing the same thing.
    I need to run my fibre at least 10 feet from where it currently is to my current proposed ideal location if I want to do this.
    But that’s currently small potatoes considering I need to do all my wiring throughout the houses still.
  12. #152
    Those Telus set-top boxes don't have to be wireless. You can run em hardwired. Seems like that's worth doing if you are being anal about all the other stuff.
  13. #153
    May 2008
    Wildflower Ranch
    Neo-Liberal Anarchist Mobile
    My Optik tech insisted on putting the farthest satellite set top box on wireless and the closest box wired. I have no idea why.
  14. #154
    Your optik experience will definitely be a million times better wired.
  15. #155
    Yes, our wireless set top box is flaky.
  16. #156
    Oct 2003
    ute
    Do you think it would benefit to have the optik hardware on its own vlan - assuming that I can get it all working through my switch rather than Telus hardware?
  17. #157
    Not Aspen
    Two from Freemont
    The reason I ended up with Optik on it's own network was back when TELUS 75 was the fastest speed, I was experiencing contention. I don't know if it was the TELUS router that was bogging down or something else.
    I dropped Optik when I got 150 but kept my setup with two networks. My XBOX is the only thing that runs on the TELUS router.
  18. #158
    Oct 2003
    ute
    I'm not sold on Optik yet. We haven't had TV in 5 years, and I don't miss it with a good plex server and Sonarr. I do use my dad's login for TSN and Sportsnet, so that helps.
    As for fibre: the point of entry into my house for all of the utilities is not my main utility room, which is in the middle of my basement floorplan, not along an exterior wall. When the fibre comes to your house, is there a termination that they then route internally with a separate cable to where your equipment is?
  19. #159
    They can located the Telus equipment kind of anywhere. In my house, the glass comes to my basement beside the breaker panel, then copper to my main floor office, then Telus modem, and optik wifi router and my asus wifi router.
  20. #160
    Oct 2003
    ute
    Right, but I want them to locate the ONT at my rack as per discussion above.
  1. TELUS Fibre Optic
    By 16hypen3sp in forum Home and Garden
    Latest Threads: 08-11-2014, 07:48 PM
  2. Shaw Fibre-to-the-Home (FTTH) Trial
    By ipeefreely in forum Computers, Consoles, and other Electronics
    Latest Threads: 08-31-2013, 05:41 PM
  3. What should be paying telus for fibre (at existing location)
    By thetransporter in forum Computers, Consoles, and other Electronics
    Latest Threads: 10-10-2012, 03:29 PM
  4. Telus or Shaw FTTH Fiber to Home Connector?
    By eblend in forum Computers, Consoles, and other Electronics
    Latest Threads: 03-01-2011, 12:05 PM
  5. TELUS will be providing new homes with FTTH
    Latest Threads: 03-14-2010, 05:34 PM
