Originally Posted by
buh_buh
Been having some issues with my commuter of late, getting chain slip (feels like the chain jumps a tooth) anytime I'm putting the power down and got worse and worse as the weeks went on.
So this weekend, changed the freewheel cassette and new chain, but still getting a bit of slip. Could it be the front chain ring is also too worn? Or is there something else I'm missing? It's a freewheel cassette, so its essentially a brand new freewheel. Not sure what other moving parts there could be that could cause a slip/jump.
I'd look at the derailleur hanger to make sure it's straight (with a tool, not with your eyes) and go through the derailleurs (redo the limit screws and re-index). If that's not working then could be worn chainrings, they're pretty cheap to replace if you just get a chainring or two. A LOT of issues end up being a bent derailleur hanger....get someone to check it with a derailleur hanger tool.
Several studies have investigated the relationship between intelligence and the degree of religious belief (excluding humanism), with most showing an inverse correlation between intelligence averages and the "importance of religion" to the testee.
