counter-top roasting? - Beyond.ca - Car Forums
Results 1 to 20 of 29
Thread: counter-top roasting?
    Oct 2003
    ute
    Default counter-top roasting?
    In an effort to move to a more healthy lifestyle, I've pre-packaged some chicken breasts and salmon etc into single portions. I plan on firing them into a sous vide mid-morning, and then sear or roast when its time to eat. I dont mind pan frying, but its a bit hands on. And firing up the oven to do a single serving is slow and annoying.
    Anybody here have any experience with one of the compact counter-top ovens for this type of thing?
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Like a toaster oven? Love my toast oven. Also use it over a toaster or a microwave... best way to reheat things too. Mine even has a convection setting
    Stampede Central
    is pretty sharp lookin'
    What are you trying to accomplish?
    If you SV the protein, it is already cooked through and your goal now is only to brown it. That only takes 1 or 2 min in a pan, or it would take maybe 5min to broil in a toaster oven (I love mine).
    I don't see how the oven would be "more hands off" if the whole process is only 3min in a pan vs 5min in a toaster oven.
    You could also consider something like a George Foreman to get the grill marks? Again, not sure how this makes it "more hands off"
    Ultimately, yes you would save time over using a conventional oven based on your portion size, but I don't see how the toaster oven / George Foreman would save you time or hassle, especially if you are looking at it only for this one function.
    As for results, because the oven is about heating air, whereas the fry pan or grill press is heat on contact, you will see different results. The Oven would only produce better results for evenly browning skin-on chicken breasts, whereas a skinless breast would get better colour from contact with the pan / grill.
    George foreman style two-sided griddle is a great idea. Get yer sear with no hassle in under 5 minutes.
    look, if you stick your dick on my shoulder, then I'm gonna stick my dick on your shoulder. That's how shoulder dicks work.
    Hybrid
    For decent results, you're pretty much stuck with pan searing (or you could try a torching, but that's no less hands off than pan searing)... countertop ovens will overcook your sous vide protein before there's any decent browning.
    Or take it outside and use your infrared searing burner
    Jan 2003
    Butane torch
    Torch Time
    Get a searzall
    '14 Taco
    Also, both chicken breast and salmon will be kinda gnarly texture-wize if you SV them for 8+ hours.... They're relatively fast so even if cooking from frozen they're max 2 hours with the SV, depending on size
    Just automate the SV start for a more reasonable amount of time. Bags in ice bath setup on counter. Start SV from phone from whenever.
    Oct 2003
    ute
    I might just skip the SV and roast the protein directly in the counter-top.
    I'm just trying to manage a way to eat non-shitty food for lunch.
    Stampede Central
    Again that depends what you are using the appliance for, and if you are doing skin on chicken.
    If you are roasting a skinless breast in a countertop oven you won't be getting very good results. My favourite way to mitigate this is cheese and mayo but then that defeats health lol
    https://www.101cookingfortwo.com/par...aked-skinless/
    To cook a single skinless/boneless your best bet would be fry pan or the George Foreman type. I had a Gordon Ramsay grill and found that I didn't have enough other uses for it to justify. Also beware that there is splatter that comes out from all around
    https://www.walmart.ca/en/ip/gordon-.../6000065627093
    Overall I really like my toaster oven as it's also good for reheating Chinese bakery buns from frozen, good size for a portion of frozen fries or a few slices of leftover pizza. I get a lot of use out of mine.
    Things to consider when getting a toaster oven:
    -Size and shape. Some are wide and deep but not tall.
    -Functions. Some are literally just "toast" to different temperatures whereas some can let you choose top or bottom elements only.
    -Timer. Mine is digital. My experience with dial ones is you hear the endless ticking until time is up.
    -They are all generally poorly insulated so be careful where you place them.
    -Rotisserie functions?
    -Tray functions for clean-up. Mine came with a tray that slides under the main rack to catch stuff, in addition to the bottom crumb tray.
    -Door. There's french door ones now and there's ones where the door is so cheap it barely holds up; opens downwards with a clunk onto the counter.
    Oct 2003
    ute
    Thinking this
    Breville BOV900BSS The Smart Oven Air Convection Oven, Large, Silver https://www.amazon.ca/dp/B01N5UPTZS/..._oQg1DbKX2BCEG
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Good chicken is easy in an oven... 225F for a while with some seasoning, then slap on some bbq sauce and broil for 5min or so to tack it up. Juicy and delicious
    Am I wrong in thinking that convection is not a useful feature for broiling/browning?
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Not too useful for broiling, but I do find it browns way more evenly
    Mar 2009
    Silverado
    Thinking this
    I have this oven in the man cave. Love it.
    Aug 2002
    992 T-hawk Golf R
    Quote Originally Posted by ercchry View Post
    This. We’ve never owned a toaster and reheat most stuff in the toaster oven.
    I like neat cars.
    Apr 2004
    I'm going to get this. Hope the quality of this will solve everything that I have my uni-task appliances for.
    https://www.amazon.ca/Emeril-Lagasse...kitchen&sr=1-3
    Concept is good, hope it can deliver.
    So how is any of this shit any better than just turning on your real oven?
    Seems like 1 more redundant appliance to store.
    Jul 2006
    Victoria Park
    Faster to heat/cook, more even crisp.
    Same reason why I would use my big boss convection/infrared oil-less cooker way more than the oven. That thing cost me $60 and makes such crispy and moist chicken.
  1. Roasting a large pig during a full out fire ban
    By CompletelyNumb in forum Travel and Vacation
    Latest Threads: 07-21-2017, 05:00 PM
  2. Air conditioning experts, I am roasting.
    By ZZT23 in forum Mechanical
    Latest Threads: 08-05-2016, 07:47 PM
  3. World's First Comedy Roasting League [in Calgary]
    By simonlexington in forum Entertainment
    Latest Threads: 11-24-2010, 01:17 PM
  4. where to buy a pig for roasting?
    By MintRacer in forum Food and Dining
    Latest Threads: 07-12-2010, 09:26 AM
  5. How-To: Burning out without roasting your clutch
    By Sykes in forum General Car/Bike Talk
    Latest Threads: 05-04-2010, 10:45 PM
