Concrete Lifting/Mudjacking Company Recommendations? - Beyond.ca - Car Forums
Results 1 to 19 of 19
Thread: Concrete Lifting/Mudjacking Company Recommendations?
    Apr 2004
    Default Concrete Lifting/Mudjacking Company Recommendations?
    Anyone here have experience with Concrete Lifting/Mudjacking companies in Calgary? One end of my driveway is sagging quite a bit so looking to get a quote to fix it.
    TIA.
    Subaru Outback
    I used a concrete lifting company to slightly lift some of my concrete but more so they could fill a massive void under my driveway (with expanding foam) as I had a village of voles under there that had set up shop.
    I used a place called Artisan Concrete. Owners name is Carlito and he was great to deal with. Actual cost came in very very close to the initial estimate. It's a bit of a crap shoot with the estimate and actual costs as you never know how much foam you will need.
    Feb 2020
    Aspen Ne
    Quote Originally Posted by Pacman View Post
    What was your final cost?
    We had our back patio mud jacked, it was done under warranty but the crew who did it said it would cost the builder around $2K. The cavity underneath was massive, 2-3 feet in some places, so I am not sure if that affected the cost. They used the type of "mud" that is kind of like grout, at least that's how they explained it to me. My neighbor had the exact same thing done (fill a huge cavity so he could put a hot tub down safely) but they used foam instead and it was much cheaper at $800.
    Apr 2004
    Do you remember which company? I was hoping mine won’t be $2k (I think I want mud vs foam) but I guess I’ll get quotes and see how it goes
    I'm sorry I don't know who did it, because it was a warranty job the builder took care of everything. Their truck was in the alley and they ran a hose through my garage to pump the 'mud' into holes they drilled in my patio slab. If you don't have a 2-3 foot deep cavity to fill I imagine it would be cheaper than mine, but that's just a guess.
    Foam seems to be at least half the price but I don't know enough about it regarding driveway use. It was good enough for my neighbor's hot tub to sit on top of though.
    Aug 2007
    dad van
    Check out polyboss.ca I used to work for them. They do foam slab-jacking.
    The only issue I have seen with Driveway's is they can sometimes have massive voids that you don't see right away that can eat a lot of material.
    In regards to mudjacking VS foam. Mudjacking is going to leave a larger hole to be patched just due to the size required to pump the grout in. You are also adding a lot of weight with mudjacking so if the base is iffy(which if it has sunk is likely the case) you are adding more weight to it vs foam. However once you get over minimum charges for large voids mudjacking can be cheaper.
    Subaru Outback
    Quote Originally Posted by 2020 View Post
    roughly 1k
    Oct 2008
    Car
    Beyondfoam did mine. Was only $600-700 for mine
    Oct 2003
    ute
    bump, I've got a 24-30" and maybe 8 foot long void that is probably from rainwater erosion under a corner of my driveway. Only about 3-4 inches deep, and accessible from the side. Can the foam guys just inject in the side if they have access like that?
    I suspect that yes they can.
    I used Ener-Spray and was very happy with them, although it wasn't for mud jacking, just wall insulation. I'd still call them first.
    Apr 2004
    I would give Concrete Experts a call to take a look. I had a few people over for quotes and they seemed the most professional. I didn’t end up going ahead with my project as it didn’t feel worth $2100 to me for my situation. Decided to put that towards a garage heater instead which I think I’d actually appreciate more.
    Apr 2004
    Also I assume you want them to go from the side because you have a nice aggregate driveway? Found this on one of their google reviews, the hole from the top gets patched pretty nicely:
    V167
    ^good to know. Thanks for posting that. I may need to do the same in future and was worried re the hole.
    You'll start to opposite-of-appreciate your driveway in a big hurry if it turns into a mess like Killramos had. I hope your gamble pays off.
    Mar 2005
    POS
    I just got a 3'x20' sagging walkway and a portion of my driveway foam jacked about 2-3 inches by Beyond Lifting. I don't have fancy aggregate so the hole patches are pretty noticeable. They were 1 of 3 quotes we got ($700, $1100, $2300) and they were the middle one and we went with them cause they just seemed more knowledgeable and professional. The most expensive one seemed like a used car salesman and wanted to come the next day to do it whereas Beyond lifting we had to schedule a few weeks out. I'm happy with the results and they injected through the top of the concrete even though the sides were accessible but I also didn't ask about doing it from the side so not sure if they can or not.
    It’s a cross I have to bear every day… though my hack patch job helped a ton.
    Sep 2012
    Yours needs to be ripped and out and repoured.
    Oct 2003
    ute
    Quote Originally Posted by gcoap View Post
    I used these guys. Happy with the work.
  1. Concrete lifting?
    By JDMMAN in forum Home and Garden
    Latest Threads: 01-10-2017, 08:38 AM
  2. Recommend a Concrete contractor/company
    By 2000Accord in forum Home and Garden
    Latest Threads: 03-26-2014, 06:58 AM
  3. Replies: 28
    Latest Threads: 05-26-2012, 08:23 AM
  4. LF - company for small concrete or paving stone job
    By urban.one in forum Home and Garden
    Latest Threads: 08-19-2011, 11:15 AM
  5. Replies: 4
    Latest Threads: 08-04-2009, 06:37 PM
