Dual Monitors vs. Ultra Wide Curved Monitor - Beyond.ca - Car Forums
Page 1 of 3 1 2 ... LastLast
Results 1 to 20 of 43
Thread: Dual Monitors vs. Ultra Wide Curved Monitor
    G05
    Default Dual Monitors vs. Ultra Wide Curved Monitor
    I'm currently using 2 24" monitors for work and was wondering if it's worth going to a ultra wide curved monitor as some people said it's better for the eyes?
    I know the 34" isn't a bad price but once you get past that you might as well just go for the 49" which isn't cheap. What's your thoughts? Should I continue with my current setup or fork out the money and go for the 49" curved monitor?
    On a side note I do run multiple applications at all times and occasionally even use my laptop as a third screen.
    I personally think dual is a better solution for most people. If you break one, you can replace them individually, and still operate in the meantime. Plus it's more of a "standard" setup, which is something I'm really seeing the value in these days.
    Sep 2016
    Calgary, Ab
    2021 Zonda CRV
    What kind of work do you do? Data, browswer type applications etc?
    Is it a work laptop, are you allowed to install applications?
    I work with a ton of data and have compare stuff on different applications, dos, bespoke and browser.
    I bought two monitors. The work laptop does not reconise a third and I had to run a cheap doc to connect. The laptop only had 1 HDMI port.
    Two montiors was great. I could just about put two applications on one screen. But again depending on the application not all resize. Access does not, so that takes up the whole screen(with three tabs) on one monitor. I run two applications on the second. Plus email, teams, browsers with multiple tabs as popups.
    I got a 49'. It takes a while to get used to. I run three applications side by side. I can compare stuff with a bit more ease. I still need to pop up email, teams and browsers. But for the intense data stuff I do on mutiple applications. It does help.
    Edit: Here is a thread that might help: https://forums.beyond.ca/threads/415...hlight=Monitor
    Sep 2002
    CGY
    Cayman, F150, Crosstour
    Quote Originally Posted by s2k_boi View Post
    IMO. I would go with the 49". I used to run 3 24" monitors for trading, went to one large screen. It is quite easy to snap an application into a 1/4 of the screen and therefore the large screen acts as 4 monitors, plus I use the laptop / surface as a reading screen.
    Oct 2003
    ute
    I use triple 34" curved. Once you get used to it...
    Does one need a fancier GPU or some other component to be able to run a monitor bigger than a TV from 10 years ago?
    Our new genius Remote Desktop platform doesn’t support second screens. So that’s fun.
    - - - Updated - - -
    1 or 2 4K monitors should be doable by any computer. More than that you might need a real GPU.
    My life hack, my dual monitor I position it like a wide "V".
    Reduces overall eye travel across and it's cheap.
    Sep 2008
    NE
    Ram 1500, '68 Camaro, S14
    pics if not lying? i got 3 - 27's and that's pretty damn wide already lol...
    - - - Updated - - -
    What remote desktop? our windows one works on two
    Bicycle
    Single screen can give you the real estate but you'll need FancyZones from PowerToys (or Windows 11 which function is now native) to set up zones to snap windows into to mimic multi screen.
    I used to have a 34" curve but now I'm on a 48" 4K flat and set up 2x 1080p zones and 1x 1920*2160 for vertical scroll all while my laptop's screen is where all the communication tools lives. Running single HDMI cable is also the perks.
    Quote Originally Posted by JfuckinC View Post
    Windows RDP worked fine before.
    They instead decided to stuff RDP inside VMware horizon and it’s useless
    He's going for an arcade setup.
    Bicycle
    I assume he's going for vertical stack. I can't imagine neck strain on 2*34 Horizontally, let alone 3.
    Oct 2003
    ute
    Quote Originally Posted by Xtrema View Post
    no...I have like a surround view going on. I'll take a pic - good excuse to clean my desk up. I don't like stacked since I don't like looking up.
    2x 27" as my main monitors and a 13" Surface Pro as my third "email" screen.
    I run everything through a docking station.
    Bicycle
    Damn.
    Feb 2018
    2013 328i, 2020 BMW F900 XR
    Work provided 2 24" flat screens and a laptop. I use one screen for my AutoCad drawing, the other large screen for all the sub menus, and the laptop screen for email, teams, etc.
    Mar 2005
    2013 C63 AMG , 2022 Acura RDX A Spec, 2005 BMW M3
    i had 2x 32" 4K monitors hated how much space they took up so I replaced it with one 38" ultra-wide Dell with USB C. The extra height of a 38" over 34" was worth it
    2013 C63 AMG Sedan
    2006 Nissan X-Trial
    2005 Bmw M3 vert
    2008 Ducati 848
    1977 Ford F150
    Stampede Central
    is pretty sharp lookin'
    Sounds like ours was implemented better
    Aug 2009
    4Runner
    I had 2 24" monitors, switched to a 34" UW with a pretty good curve to reduce eye strain. Was a bit to get used too, but now that I am, I wish I got a 38" or 42" instead.
    I split my monitor 3:1 (CAD : Drawings), it would be nice to have more room to read drawings without adjusting CAD size.
    The monitor itself took a bit of room on my desk, but a monitor arm fixed that!
  1. Recommendations on large curved monitors for office use?
    By FixedGear in forum Computers, Consoles, and other Electronics
    Latest Threads: 06-29-2018, 03:28 PM
  2. FS: Custom PC w/ Dual Monitors & Dual Monitor Stand
    By HR-ZD403 in forum Computer Hardware & Peripherals
    Latest Threads: 09-09-2016, 10:38 AM
  3. FS: 34" LG 21:9 Ultra Wide Monitor
    By DontBannMe in forum Consumer Electronics
    Latest Threads: 06-25-2014, 09:24 AM
