Why did this wheel fail? - Beyond.ca - Car Forums
Page 1 of 3 1 2 ... LastLast
Results 1 to 20 of 58
Thread: Why did this wheel fail?
    V8s
    Default Why did this wheel fail?
    Alright, since this is (ostensibly, at least) a car forum, I've got an actual car question.
    The wheel failed/fell off my MIL's car today. It seems the center section just sheared itself away from the rest of the wheel. Anyone know what would cause this? I can't think of a reason, aside from improperly torqued lugs - but that seems like quite a stretch.
    Pic for reference:
    @tirebob do you have any thoughts? My only thought is its NOT improper lug torque. Possibly manufacturing defect in the wheel? Although steel wheels should be reasonably strong. They don't look rusted or anything that indicates they be weakened either.
    Only 15min from Aspen!
    Nothing interesting anymore
    Chinesium alloy steel.
    Feb 2003
    DT 780
    LEXUS LX470
    Too much NOS. She's just lucky she didn't blow the welds on her intake manifold.
    Tap, Rack, BANG!
    The SHBARUS
    vtec kicked in? Haven't seen that before. I don't think it's from under/over torquing.
    Now I have seen a lot of shit in my day, but never have I seen a steel wheel with the centre broken out like that so perfectly! That is a head scratcher for sure. I mean steel bends... Sure you can break it but I think if that wheel was hit from the side or anything to the degree that would be needed to break the rim, there would be some kind of extra obvious damage. Over or under torquing I cannot see causing that either. I mean if the rim was loose and banging around it could cause some damage to be sure, but it would have been obvious and just seeing the centre still attached to the hub leads me to believe that is virtually impossible to have happened.
    My instinct says some kind of defect but as to what I can't say for sure... That is crazy!
    Dec 2006
    Nothing worth mentioning.
    Bad welds. Chinese wheel. Corrosion/bad welds.
    Need better pics.
    C-Spot
    11sec S14, Lux Family Bus, VQ35HR
    I can see aluminum breaking. But steel wheels? That's crazy.
    How cold was it? and to make it break in a circle.
    She wishes it was deep.
    So deep put her ass to sleep.
    Shitty welds, too much curbage and dukes of hazzard
    The SHBARUS
    black wheels matter
    V8s
    It happened today, so not that cold. The wheel broke very shortly after she got off Stoney trail, thankfully it didn’t happen at speed.
    Glad to know I’m not the only one stumped by this.
    Oct 2004
    Rage2
    definitely shitty welds, maybe combined with some curbing...
    Nothing to do with lug torque
    Only other possibility might be the wrong wheels and it was dragging on the caliper scoring the inside of the wheel creating a weak spot.
    User title molested by Rage2.
    ^^ Fact Checked
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    I would think that whole face would be stamped, no welds?
    Would appear to be defective, bad tolerances on the die or build up of materials, over working the material
    Or a combo of that + over torque, hard to tell from the photo but looks like it aligns well enough with the edge of the brake rotor, that could have been enough force to tip it over the limit if the torque was high enough to disfigure the face of the wheel
    We’re they hub centric? If not the vibrations could have also tipped it over the edge
    Nov 2021
    E46
    The center of the wheel is one piece that is welded to the barrel of the wheel, there is no welds on the front part of the wheel.
    My vote is something got caught in between the brake caliper and wheel, and cut the wheel apart. When Chevy/GMC trucks went from rear drum brakes to disk brakes, rocks would get caught in between the caliper and wheel and slowly cut the barrel of the rim until it blows apart. I have seen brake pad shims slip out and cut brake rotors off of the hub.
    You don't see that every day.
    V8s
    Debris or something caught between wheel and scoring it seems like a potential scenario. She didn't mention any sounds though.
    I believe they are hub centric. Zero chance they are the wrong wheels and dragged on the caliper (the failure area isn't close enough to the caliper, caliper isn't scratched). There were no vibrations either (I drove the car within the last week) and she's pretty cognizant re: new sounds and stuff like that coming up, she's not a typical clueless old lady.
    Quote Originally Posted by Flexray View Post
    I suspect that the bolt circle & flange piece are certainly welded on (exactly where it failed) so that China can keep making China things in China ways.
    "Heat Affected Zone" causes ductile-to-brittle metal behaviour.
    Oct 2003
    ute
    conversion to center lock wheel.
    Dec 2006
    Lease
    Nov 2021
    E46
    Quote Originally Posted by bjstare View Post
    Every now and then I will pull a wheel off of a car, the noise damper shim on the outboard brake pad has slipped out and cut a few mm slice into the hat of the rotor. The owner was not complaining about a noise, most of the time I have driven the vehicle and heard nothing. Same thing with stuff rubbing on drivshafts, sometimes they don't make any noise.
    I don't know if I have ever seen a bolt circle welded into the face of a wheel, not saying they don't exist but I don't think I have ever seen it.
    Jul 2008
    North North Dakota
    Nissan x2
    Damn. How old are those wheels?
  1. Tim Hortons Hoe - Parking Fail, Life Fail
    By Modelexis in forum Society / Law / Current Events / Politics
    Latest Threads: 03-24-2016, 11:47 AM
  2. Trying to burnout fail riding bike fail
    Latest Threads: 10-02-2012, 08:25 PM
  3. why why why wireing gone bad
    By stevo 27 in forum Mechanical
    Latest Threads: 06-07-2007, 12:34 AM
  4. Why does dieting fail?
    By Tyler883 in forum Health and Fitness
    Latest Threads: 02-11-2005, 04:49 PM
  5. Why, why, why?
    By hockeybronx in forum Suggestion/Comment Box/Forum Related Stuff
    Latest Threads: 12-18-2004, 02:46 PM
