Recommend Home Networking Installer - Beyond.ca - Car Forums
Results 1 to 20 of 20
Thread: Recommend Home Networking Installer
    Apr 2006
    Cowtown
    10' 4Runner SR5
    Default Recommend Home Networking Installer
    We have Cat5e outlets wired throughout the house but the problem is they don't have connectors on both ends -- all the cat5e in the mechanical room are cut ends.
    Being an electrician I thought it would be painless, got the tools, got the network switch and voila. Turns out I suck at putting on data connectors. I'd also like to install another cat5e outlet beside a coax outlet.
    Who would you recommend to do this work? Any ideas on cost?
    Ultracrepidarian
    Don’t have a recommendation on someone, but try using the pass through rj45 connectors that you crimp off.
    Massively increased my cable success yield.
    VCE Shielded RJ45 Pass Through Connectors Cat6 with Protection Boots 25-Pack, Ethernet Crimp Modular Plug for Cat6/Cat5/Cat5e STP & UTP Network Cable,Interference-Resistant https://a.co/d/cMcQpWf
    I use the VCE shielded ones with good success. Don’t go buy crap at Home Depot and expect good results.
    Apr 2006
    Cowtown
    10' 4Runner SR5
    Hmm interesting, thanks man. Same crimp tool I assume?
    This was originally the package I tried, and getting everything perfectly trimmed and seated in the connector was driving me nuts.
    https://www.amazon.ca/gp/product/B08...?ie=UTF8&psc=1
    Ultracrepidarian
    Yea getting all 8 cables exactly straight and all the way to the end in the right order without passing them through is impossible without breaking something along the way.
    With the pass through you cut them to the right length after which is way way easier.
    I have this crimp, as long as it has the blade to cut the excess when you crimp the connectors you should be good.
    VCE RJ45 Crimper Pass Through, Ethernet Crimping Tool for Cat6 Cat7 Cat5 End Pass-Thru Connector, Support Stripping & Cutting https://a.co/d/5MeDzbu
    The connectors that come in those packages are hot garbage.
    Oct 2003
    ute
    I have a pass through tool you can have and a bunch of connectors. I prefer old school.
    Sep 2008
    NE
    Ram 1500, '68 Camaro, S14
    It's a pain but you'll figure it out. Took me while. Killramos is right, better tools will yield better results. Do you have a tester?
    Honestly at first when i was doing it, i was stripping all the individual wires lol
    Apr 2006
    Cowtown
    10' 4Runner SR5
    Shoot I just ordered some stuff, should arrive tomorrow. But thank you!
    Quote Originally Posted by JfuckinC View Post
    That's definitely what I was doing too and was driving myself insane
    Ultracrepidarian
    Oct 2003
    ute
    Omg...I want video of this
    - - - Updated - - -
    Also... Spread them and order them before you clip them to size. Them just shove them in there and crimp.
    A cable tester is a help for this too. So you can confirm you didn't get the wires mixed up. The cheap blinky-light kind is fine.
    sounds like I'm gonna call @killramos when I need some CAT 5/6 ends done.
    Sep 2007
    golfR
    Has anyone used a company to add drops?
    I'm looking to have some added on the soffits for cameras, in the attached garage, and living room.
    Looking for costs as I'm not sure if it's worth my time and effort to DIY.
    Sep 2012
    Quote Originally Posted by chongkee_ View Post
    No idea on cost, but Neutech does this sort of stuff.
    Aug 2006
    calgary/AB
    95B
    I used these guys http://www.hutchtech.ca/ to do the drops for my camera.
    They charged $115/Drop for me
    Thaco's Avatar
    Oct 2004
    Rage2
    the company we use for work is up to like $250+ a drop now and that's easy runs in a commecial building with drop ceiling, i have to image residential is a lot more difficult and that's likely why the company we use doesn't even entertain residential service.
    installing crystals on the ends DIY is very easy once you have the right technique, just watch a couple videos on it...
    also i agree with buster (eww), those passthrough connectors are a PITA, and if you dont have the right tool to flush cut the wires exactly, then they cause problems with pushing the end fully in to the socket, i have passthru connectors and still use the OG connectors.
    User title molested by Rage2.
    ^^ Fact Checked
    Oct 2009
    rally pig
    had these guys run 2 cat6 cables in our house, basement to main floor. called them on a weekday and they came over the weekend.
    cost was surprisingly cheap, 2 cat6 plenum cables through the heating vent and was under 250$ from what I recall
    First time in recorded history that cats could be useful.
    https://youtu.be/GEX-IOAkqHA
    Not Aspen
    Two from Freemont
    These guys did my temp house. Very good.
    Apr 2006
    Cowtown
    10' 4Runner SR5
    The pass-through connectors and crimp tool listed above made short work of ~10 cables. One cable either I screwed up the connector or the wall jack isn't wired correctly. Another cable is in the mechanical room but is a mystery where the other end is LOL.
    Tonight I'll put the network switch on the board, connect everything up and pray for the moment of truth.
    Thanks for all the recommendations.
    Ultracrepidarian
    Dec 2006
    Calgary, Ab
    These guys did my house https://www.mpidesigns.net/; they're a local company and got the work done as per the budget they quoted me
  1. Recommend me a concrete cutter/window installer
    By Tik-Tok in forum Home and Garden
    Latest Threads: 05-15-2015, 01:54 PM
  2. Recommend a good car audio installer:
    By Chandler_Racing in forum In Car Entertainment / Electronics
    Latest Threads: 04-10-2010, 08:43 PM
  3. Recommend an Installer?
    By freshprince1 in forum In Car Entertainment / Electronics
    Latest Threads: 02-26-2010, 12:41 PM
  4. Anyone recommend a sub/amp installer
    By kerr in forum Alberta BMW Owners Club
    Latest Threads: 05-14-2007, 12:39 PM
  5. Replies: 4
    Latest Threads: 02-18-2006, 08:58 PM
