Finboy buys a Lexus LX570 - Page 3 - Beyond.ca - Car Forums
Results 41 to 60 of 61
Thread: Finboy buys a Lexus LX570
    Jul 2002
    calgary, alberta, canada
    Mall Crawler
    I only have it on my spare at the moment, but went with feedback from Bob and a buddy who runs them. I was looking at the falken wild peak but the at3 is getting phased out for the heavier, slightly less good in the wet AT4, of which limited sizes are available currently. I expect I will be getting a mildly harsher with the Toyo, but wanted a bit more aggressive tire and wider contact pad.
    sig deleted by moderator, because they are useless
    Jul 2002
    Mall Crawler
    Dbl post
    Jul 2002
    Mall Crawler
    ute
    that color rocks
    Jul 2002
    Mall Crawler
    It certainly is a stand out, I picked up the land cruiser roof rack so that will go on soon, then I have to pull the bumper to get the last seized screws out of the passenger fog light. I’ll also be visiting Bob in a couple weeks to get the summers on, which should help it look less like a pregnant highlander.
    I got some touch up paint made local to deal with the rock chips (because Alberta). Turns out a rare colour doesn’t just have touch up pens at any Lexus dealer, thankfully the chips I found aren’t anywhere obvious.
    Nov 2005
    Blue isn't my color, but that looks frickin great Finboy. Snowflake pic, hah, I dig it, and it looks like new condition there.
    Cool find, looks like it was worth the hunt!
    Jul 2002
    Mall Crawler
    More mods, more fails. This weekend I worked more on some mods for the upcoming boys golf trip, which means loading 4 guys and golf gear through the winding roads of panorama. Lexus, for reasons unknown equipped the LX 570 with really short roof rails, and the Land Cruiser with longer rails (just under a foot). After tracking a Land Cruiser set down stateside (thanks to ih8mud), I was able to swap out the silver for black, and now have less overhang for the roof rack.
    Before:
    Going for that punk look. These studs ensure none of the bolt anchors fell into the headliner while I swapped rails (another ih8mud idea)
    Finished up and ready to load up with golf clubs as Lexus intended
    Mod 2 unfortunately stopped in motion again. If you’ll recall from my previous post, there were some diode dynamics LED bulbs in the factory housings. The seals had long since given up, there was some moisture in the housings so I opted to upgrade to the Diode Dynamics SS3 Pro fog kit which is plug and play (or so I thought). After the last attempt where the passenger side defeated me due to seized screws, I was rocking one OEM fog light that worked, and one SS3 which wouldn’t illuminate. Upon getting the screws out, I thought it was going to be smooth sailing. Sadly now BOTH SS3’s won’t illuminate, but the dash shows fog lights as on (switch works), fuse is good, we tried with high beams on, low beams on, e-brake engaged and not engaged, in park and in drive, noooothing.
    Update: one of the plugs was reversed, the other has some corrosion which might mean I have to de-pin and clean the terminal unless someone knows a better way to clear it up. When partially plugged in light works as expected, fully plugged it it is dim and flickers.
    Here is a shot of me frustratingly working on it with an old school beyonder in the driveway
    I got an oil change done as well, fumoto valve installed and a 5w30 oil cap from another global market land cruiser where they understand the folly of 0w20 oil
    More too come soon.
    Jul 2002
    Mall Crawler
    33’s are on for summer
    33's are the correct choice.
    Dig the plate. Who needs uptravel?
    Jul 2002
    Mall Crawler
    Thankful for 3” of factory hydraulic lift lol
    Jul 2002
    Mall Crawler
    De-chrome starts and general cleanup day. Chrome was all the rage in ‘08, I’m not a fan so first order today was beginning the de-chrome with OEM LC200 sills, over-week parts from Japan.
    Before:
    After:
    Previously this truck had some zero offset Te37’ s with 1.5” spacers, looked cool but definitely left some rock chips. In order to avoid future rust issues, I spent the rest of the day cleaning out, priming, then touching up each wheel well. Paint match isn’t 100% given 16 years wear and tear, but I’ll take it over rust.
    Primer:
    Finished:
    Finally I went to check on that front fog light, seems the contact cleaner and dielectric grease did it’s job, both are currently working.
    Jul 2002
    Mall Crawler
    Fun week
    Thanks to a driver of a gravel truck that didn’t cover his “empty” bed, this beauty showed up. I called the owner, and despite his buddy having a shop that could totally do this for a deal, I told him I only trusted one guy in town to replace it. He was hesitant but then other cars that were showered in rocks started calling insurance. Unfortunately Lexus of Calgary couldn’t source aftermarket glass, so brand new OEM goes in.
    On the upside
    And while I was there, replaced the old and crusty wiper arms with some new OEM units
    Calgarian Living in Edmonton
    Damn baller. Those wiper arms just need a new coat of paint and good as new but Lexus owner.
    So did the gravel truck owner pay for glass replacement? I had a construction company trailer fling a chunk of mud from their excavator but I dont think thats arguable no?
    Originally posted by GTS Jeff
    Jul 2002
    Mall Crawler
    Quote Originally Posted by dj_rice View Post
    The aluminum was really pitted, would have needed body filler/sanding and finishing work, new arms were like $40 each. Owner paid for the windshield, apparently a few dash cams caught the rocks coming out of the bed. Rocks coming from an uncovered load are likely seen differently from rocks thrown by tires, this thing was at least fist sized.
    PSG / LA
    B5 S4, UrQ, UZJ100, 990 SMR
    Damn she looks great. Would be hard for me to wheel that unit!
    Originally posted by InRich
  18. #58
    Jul 2002
    Mall Crawler
    Quote Originally Posted by zipdoa View Post
    Plate is well earned
  19. #59
    I really need to get a dashcam
  20. #60
    Jul 2002
    Mall Crawler
    *sigh* rust never sleeps.
    The Lexus Active Height Control suspension system is notoriously reliable, the Japanese did what the Germans couldn’t. Sadly they put heat wrap around one line that goes over the muffler, which tends to gather moisture over years and eventually fail. My garage is full of boxes while we prepare to move so it is going to pro-active to replace the line and put in the new accumulator globes while the system is de-pressurized.
    On a side note, I will have to address surface rust before winter, I’m thinking of a combination of pro-15 for the frame/metal skid plates, standard undercoating for the wheel wells and a treatment oil for any metal connections (ex. Brake and AHC junctions). Having not spent a lot of time on this prior, happy to hear input from beyonders on what worked for them.
  1. Home project thread - finboy buys a house
    By finboy in forum Home and Garden
    Latest Threads: 06-01-2024, 07:43 PM
  2. Replies: 105
    Latest Threads: 03-26-2024, 03:39 AM
  3. FS: 2008 Lexus LX570 SUV
    By Tuner1 in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 07-23-2014, 09:14 AM
  4. Finboy Buys a Honda
    By finboy in forum The Garage
    Latest Threads: 07-20-2013, 08:09 PM
  5. Lexus LX570 and IS-F ride and drive Gatineau Quebec
    By Redlyne_mr2 in forum Automotive News
    Latest Threads: 02-15-2008, 09:15 AM
