If the women don't find you handsome they should at least find you handy - Beyond.ca - Car Forums
Page 1 of 4 1 2 ... LastLast
Results 1 to 20 of 64
Thread: If the women don't find you handsome they should at least find you handy
    N/A
    Default If the women don't find you handsome they should at least find you handy
    An infamous Red Green saying and I nailed the handy part today.
    Rewind to 4-something this morning and I'm told there's no hot water. Get up early and start looking at the problem - no pilot light. Did the whole reset procedure several times and got it going on voila, the burner kicked in and away we go or so I thought.
    10 minutes later and heater is dead again, could get the pilot light started by it wouldn't stay lit. Thermocouple seemed like the obvious trouble point so I removed the old one and headed down to Home Depot to get a new one.
    Get back home, install the new thermocouple a.d port stays lit - I figured I was home free. Then I moved the switch to the on position and the burner kicks in - hooray or so I thought. About 20 seconds later, both the burner and pilot snuff out.
    So what now removed the burner assembly, all is good there. Put things back together and same situation. Now I know it's not the thermocouple and it's not the has control assembly and logic told me that there was a lack of fresh air. Took things apart, checked the flue and venting as well as the chimney and all is good. Did notice some accumulated dust bunnies on the fresh air vents so vacuumed them clean.
    Put things back together and still the same problem. So more reading and I discover there's a thermal reactive device that is similar to a fuseable link in that it will break if it detects a flammable vapour instance and shuts of all fresh air supply. Take things apart again and sure enough mine is kaput. By now my reading has revealed that you should regularly take out the burner assembly and vacuum out the bottom of the combustion chamber as soon and stuff can accumulate over time on the porous plate below the burner which will restrict fresh air flow and eventually blow the safety device.
    So now to get the TRD unit, called GE and they could send one out but it would take a couple of days and that I would also have a tech install it plus also have the tech check everything I had already done plus have my natural gas pressure checked. 80 some bucks for the part as well. Well after I did a rough figure of how much all this service was going to cost me plus 2 days minimum no hot water started making a new tank look very attractive.
    But I started calling around and after 6 redirects I got ahold of Amco. They did not know of the part but asked me to bring it down. Got there and there's nothing in their databases. They called GE, got a part number and came out of the back with a very dusty box with my new part in it.
    Go home, put the new TRD in, get things together and I now have a fully functional water heater
    A $34 part sourced locally that was the solution but it sounds like the solution most often suggested by the service companies is a new water heater.
    Interestingly enough, it took me longer to fix the water than it did for me to install it 11 years ago.
    Will fuck off, again.
    Fascinating. Wonder if that was what was wrong with mine when I replaced it. The beyond keyboard warriors seemed sure it was thermocouple. I never did check that either.
    Affordable Condo
    Acura Lexus
    And if you have neither good looks or skills, you better be rich enough lol
    Originally posted by rage2
    I am user #49
    Mar 2011
    Heres a nice thread this post would have fit in:
    https://forums.beyond.ca/threads/355...52#post4793552
    Quote Originally Posted by max_boost View Post
    And if not even that, you'd better have some game. None of the above matters if you have game.
    Sep 2016
    Calgary, Ab
    2021 Zonda CRV
    Jul 2006
    Victoria Park
    If I had to rank attributes from best to least on attracting ladies:
    Personality > Skills > Looks > Money
    Oct 2003
    ute
    Girls will try to tell you this. But they're either lying or lying to themselves.
    The womenfolk are attracted to men that have the ability to elevate their social status. It's all scienced up.
    Affordable Condo
    Acura Lexus
    Abundance mode is best.
    I am user #49
    Stampede Central
    is pretty sharp lookin'
    no money no honey
    Depends ENTIRELY on the maturity of the women you are seeking.
    Plastic women who cant put their phone down for a moment, yes.
    Mature women who have made their own lives and careers, not generally no .... unless youre a CEO of a billion $$$ company perhaps.
    Oct 2003
    ute
    This has been a thoroughly studied phenomenon. We're talking basic human instincts here...genetically embedded. It's not about women who are plast or who aren't.
    Its about maturity - ie Emotional Intelligence.
    Non EI / mature women will jump at a complete douche with $$$ or status.
    Apr 2011
    _
    This.
    Fuck science lol
    You're only lying to yourself and putting the pussy on a pedestal if you don't tell a woman to hit the road if "So, what do you do for a living?" is among the first 3 questions she asks.
    After a few hours into the date/initial meeting/convo that's a different story but if she's gotta know right from jump street to me that's a red flag right there so bye Felicia. No matter how hot she is.
    Everyone is a whore for the right price.
    Some are just more expensive than others.
    Oct 2003
    ute
    This.
    Fuck science lol
    She might not ask that question top3.
    But she's definitely asking it to herself. Also - unlikely she goes on a date with you before having that information anyway.
    This.
    Fuck science lol
    Not really. Most emotionally intelligent women will ask this because they have had enough of the rig pigs here.
    Apr 2011
    _
    Lol I've been on literally dozens of Tinder dates where neither of us knew what we did for a living until maybe halfway through the date.
    That is true, but also about the engineers, lawyers, investors, and the likes of which. I used to be real insecure about telling women what I do but since my breakup and 1.5 year tinder Rampage I've discovered that real women, who have jobs and homes and cars and all about the 50/50, non psycho women, the women you want, they don't want anything to do with some douchebag who thinks he can do whatever he wants cuz he owns a Ferrari and a 20k watch LOL or for that matter a lifted F-350 haha
    N/A
    max_boost, he is the king of derailing threads, Kudos to him for a job well done.
    Affordable Condo
    Acura Lexus
    Sincerely thanks speedo
    That’s a nice compliment haha it’s what I do
    Quote Originally Posted by speedog View Post
    I am user #49
  1. FS: Borderlands Handsome Collection PS4
    By yellowsnow in forum Video Games / Consoles
    Latest Threads: 07-29-2015, 09:37 PM
  2. The 2014 Jeep Cherokee Is A Handsome Vehicle
    By rage2 in forum Automotive News
    Latest Threads: 08-19-2013, 08:30 PM
  3. handy little site that might help you out!
    By 90civicrider in forum General
    Latest Threads: 07-31-2007, 10:47 PM
  4. Replies: 23
    Latest Threads: 04-20-2004, 08:12 PM
  5. A handy DIY Curb rash repair
    By ZorroAMG in forum Car Care, Detailing and Body Work
    Latest Threads: 04-16-2004, 10:42 AM
