Finally upgraded my home wifi to something that works - managed wifi review - Page 32 - Beyond.ca - Car Forums
Page 32 of 51 FirstFirst ... 22 31 32 33 42 ... LastLast
Results 621 to 640 of 1002
Thread: Finally upgraded my home wifi to something that works - managed wifi review
  1. #621
    Quote Originally Posted by ganesh View Post
    Interesting. I guess I will call again and see if they are going to allow me to do that.
    So far the answer I got was unless it is a multi dwelling setup they will not allow that.
    How are you currently setup? The way u have it done is essentially Telus’s out of the box recommendation. Literally nothing fancy and the “bridge mode” is user configurable on the router.
    - - - Updated - - -
    USW-16-POE Gen2
    which I have now discovered is SFP, not SFP+.
    Ohhhh got it. For some reason I thought you were trying to use SFP to connect to Telus, which is doable but more complicated.
  2. #622
    Aug 2006
    calgary/AB
    95B
    Current Setup is ONT -> Telus Router -> UDM Pro
    Couple ports on the Telus Router is hardwired to the Optik TV boxes.
  3. #623
    Isn’t that exactly the same as what I said?
  4. #624
    Aug 2006
    calgary/AB
    95B
    Lol. Yes. I was under the impression people are connecting directly to ONT.
    The set up I am referring to is ,
    ONT Port 1 -> Telus Router -> Optik TV
    ONT Port 2 -> UniFi network Or any gateway
  5. #625
    Sounds like in general Telus doesn’t play ball with multiple ONT ports.
    There are ways to bypass the Telus router and use the UDM Pro to handle optik but it’s not straightforward.
    Even more hardcore is skip the ont, and plug Telus fibre into the SFP port on the UDM. But again, more complication.
  6. #626
    Oct 2003
    ute
    I used a DAC cable between my udm pro and my Gen2 switch. I just ordered one from Ebay. Some vendors have a "unifi" specific one, which I bought.
    You need to set your UDM Pro to SFP / 1gig uplink manually, though. For some reason it doesn't auto-negotiate down to SFP (non plus). Or get the Pro switch which is SFP plus.
    When Telus finally finishes their install in the community, I plan to run the fibre straight to my UDM pro, no ONT. I don't plan on getting Optik I dont think. You need to use the GPON SFP they use though, can't use your own SFP.
  7. #627
    Sep 2008
    Edmonton, AB
    I went with a switch in between.
    ONT-> switch
    -> my router -> 24 port switch
    -> Telus router
    -> LAN 1 (unused, not in bridge mode could use for another network)
    -> LAN 2 - PVR
    -> LAN 3 - SMB TV box
    I haven't had time to clean things up and my old UPS died (older unit, new battery :/ ):
    Originally posted by Xtrema
    Originally posted by DayGlow
    How do you respond to stupid?
    Originally posted by rage2
    Originally posted by Seth1968
  8. #628
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    Anyone have a POE switch to recommend? Needs to be 802.3af.
  9. #629
    2015 CLS63s AMG Coupe
    UniFi has tons. Some fancy new gen ones too...
    Sig was pwned by Moderator!
  10. #630
    Quote Originally Posted by Zhariak View Post
    Is it really a switch if you can’t see what devices are plugged in where with augmented reality?
  11. #631
    Oct 2003
    ute
    keep talking dirty.
  12. #632
    Quote Originally Posted by ipeefreely View Post
    The UPS probably died in service - it saved its life in service of others /respect
  13. #633
  14. #634
    Oct 2003
    ute
    my 10gtek SFP DAC cable between my switch and my UDM Pro just stopped working randomly. I wonder if it died, or if its a software thing with the udm.
    Shoulda bought the ubiquiti one, I guess.
  15. #635
    Interesting... Have you tried forcibly setting speed on the cable?
  16. #636
    Oct 2003
    ute
    well, I set the port on the UDM pro to be 1gig not 10 gig (SFP vs SFP+), so I guess so?
    It just randomly stopped in the middle of a netflix show. I think it might just have died.
  17. #637
    Apr 2006
    2011 Ralliart SB
    Is anyone running a HDnano access point, and what kinds of speeds are you seeing.
    Setup a test rig today, with mostly default setting, on 5GHz, with a VHT channel width of 40, I was only getting 200 MB/s using a Samsung s10, via the ookla speed test app. When I check the wifi settings, it registers as a 300MB connection.
    To my Asus 68u, my 5Ghz wand gives me a 420 MB connection estimation, so I must be missing something.
  18. #638
    Give it some time to negotiate a higher speed.
  19. #639
    Quote Originally Posted by colsankey View Post
    My S20 Ultra was getting the same results as you at 220mbps down...
    I tested with my 8 year old Lenovo Carbon X1 and got the following. My testing isn't the best as I have downloads going, and I don't know which of my nanoHDs I'm connected to ATM (1 goes through a couple switches first cuz of distance)...
    EDIT: I think I'm using the same channel width as you are.
  20. #640
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    I average around 450mbps on mine, peaks around 500mbps on iPhone XR and Telus fibre.
  1. Finally upgraded to a dual band DD-WRT router
    By WhippWhapp in forum Computers, Consoles, and other Electronics
    Latest Threads: 04-04-2017, 10:49 AM
  2. FS: HP Procurve 1800-24G managed network switch
    By Smokem in forum Computer Hardware & Peripherals
    Latest Threads: 03-14-2012, 06:09 PM
  3. Managed Funds
    By cidley69 in forum Real Estate / Finance
    Latest Threads: 02-23-2012, 08:44 AM
  4. Something, something, something, Dark side
    By Tik-Tok in forum Entertainment
    Latest Threads: 12-27-2009, 08:15 PM
  5. FS: Netgear FSM726S L2 managed Switch
    By 02WhiteWs6 in forum Computer Hardware & Peripherals
    Latest Threads: 11-16-2007, 05:03 PM
