PastramiThis quote is hidden because you are ignoring this member. Show Quote
Brisket??This quote is hidden because you are ignoring this member. Show Quote
So it was a 15.2Lb brisket and I trimmed about pound of fat. Salt and pepper, no other prep. 14 hours at 250F, wrapped in butcher paper at 6.5 hours, rested in foil and towels in a cooler for 2.5hours. Just a water pan for moisture, no spritzing or mopping.This quote is hidden because you are ignoring this member. Show Quote
Took a chill approach instead of stressing like previous times.
Yeah I run a pretty chill brisket too. I don't even wrap, but I bump to 275 to power through the stall.
Looks good, can’t fault the method... but I would recommend splitting out flat and point before slicing as the grains run in different directions
I'm awful at that. I find it really tricky. It really doesn't seem to be, but somehow, it is?This quote is hidden because you are ignoring this member. Show Quote
Yeah I split it and turned the point 90 degrees and continued slicing. Not obvious by they way I setup the picture.This quote is hidden because you are ignoring this member. Show Quote
It makes me wonder... is it better to let it reach 165 for a second and then take it off, or let it sit at 145 for ~6-8 minutes which should be safe too.. Plus, there is residual heat as well when you cool it.This quote is hidden because you are ignoring this member. Show Quote
Guess it might depend how long it takes to go from 145 to 165 too..
165 isnt needed at all.This quote is hidden because you are ignoring this member. Show Quote
Exactly.This quote is hidden because you are ignoring this member. Show Quote
Somebody please think of the chickens.
Sobey's has whole brisket packer cryovac for $2.99/lb. Good price.
Wow! Half off! Covid contaminated specials cheap haha... which location? I feel like these sorts of things aren’t usually stocked at every storeThis quote is hidden because you are ignoring this member. Show Quote
+juan any stores in the south confirmed with stock?
Briddlewood sobeys has it on their flyer (sending my house elf now to confirm) of course aspen doesn’t get the deal. $3.99 brisket “pot roasts” at that oneThis quote is hidden because you are ignoring this member. Show Quote
I am out of the city, so I can't take advantage. The seton/Cranston location had stock this morning.
Guess I'll venture out into the monsoon now
Just bought one in Silverado, there was 4 left, 2 decent for the size/price and the other 2 had too much fat cap
Briddlewood has about 5 left, big fuckers... she brought home a 16.7 and 17.6lbs pair, and hilariously enough I think this actually is covid meat... label ends in “cov”
Mine says the same, if we die....we die....
Gonna trim and salt, salt should fix it, right? Maybe better off doing MTL smoked meat with them? Nothing will ever survive thatThis quote is hidden because you are ignoring this member. Show Quote
