Utility room is wired with 12 Ethernet drops (2 to each room) i need to get a netwrok switch to get all working.
right now i just have the few connections i use everyday plugged into the back of the router.
also have 6 POE drops for security cameras in the same spot.
my questions are.
i could go with a 8 port poe Network Video Recorder for the cameras. and then a network switch large enough for the 12 Ethernet and be done.
or if i went with a pc for the security instead of the NVR. Would i need like a 24 port network switch that has poe ports and regular ports for rj45?
or what is the best way to set up what i have.
i like the idea of a NVR as its plug and play.
but is the pc the better way to go with the right software. what is the right software? my wife wants to be able to access the footage on her iphone also.
