Finally upgraded my home wifi to something that works - managed wifi review - Page 16 - Beyond.ca - Car Forums
Page 16 of 51 FirstFirst ... 6 15 16 17 26 ... LastLast
Results 301 to 320 of 1002
Thread: Finally upgraded my home wifi to something that works - managed wifi review
  1. #301
    Grimace
    I finally got a nanoHD. It is OK, but there is always lots of interference on 2.4 compared to the Pros. I should probably make a separate 2.4ghz IOT network and then push everything that can to 5 ghz.
  2. #302
    Hybrid
    Bump.
    Looking to upgrade my network during Black Friday. What do I need to get up and running with Ubiquiti? They have the new Dream Machine which replaces one AP, PoE switch, cloud key, and gateway, but it's a bit pricey... is it worth it?
    I have drops for access points in the ceiling of each floor, but I'm thinking 3 APs and a router is probably overkill for a 2,800 sq ft house.
    I also need PoE for cameras... am I better off to buy a single PoE switch for everything rather than using an injector on each AP?
  3. #303
    Quote Originally Posted by Strider View Post
    Bump.
    I typically shy away from 'AIO' devices like this - especially if its brand new. I prefer a decentralized approach - a router + WAP.
    With the selection from Ubiquiti, I also run into comparison issues quite often - as they have such vast selection. They do have a good tool to help out though.
    I have a 3 story, 2600sq ft house and I have 1 UNIFI LR AP upstairs and one low power unit in the basement.
    If you have many cameras (more than 2), having a dedicated PoE starts to make sense.
    Network infrastructure is something I see so many people cheap out on - a serious home network for a typical power user will be north of 500$, but its also something that wont have to be worried about for years. Thats why with decentralization, you can upgrade your router hardware and keep the existing WAPs.
  4. #304
    I like my in wall HD’s. But the range on them is a bit to be desired, seems like they don’t really have the same antenna setup as the domes.
    I think I would go with UFO style instead next time. The in wall HD is cool in that it functions as a 4 port switch as well which is awesome for a home office to replace a switch and an AP all in one.
  5. #305
    Oct 2003
    ute
    Two aps will be plenty. I'm at 5500 sq feet and only use two.
  6. #306
    The range will be determined by the least powerful/farthest range, device's ability to talk to the WAP, not the other way around.
    Having 1, 500$ HD AC LR unit for eg. is less effective that 3 lower priced, spread out units, in a large environment.
  7. #307
    Aug 2006
    calgary/AB
    95B
    +1 I have couple of in wall HD's and their signal strength is questionable.
    I am going to add a BeaconHD and see what kind results I am going to get. If they work as advertised I might add another couple.
  8. #308
    Oct 2003
    ute
    im still waiting for ubiquitis new HD4 router to come out
  9. #309
    That and Wifi 6 would be great to have.
    Unfortunately I might end up running my next network in mesh for the next bit here. I don’t think I have any Cat5 anywhere.
  10. #310
    If you have coax you can give yourself some gigabit ports around the house. MoCA 2.5 so full duplex gigabit.
    https://www.gocoax.com/
  11. #311
    N/A
    Which providers can get you full duplex gigabit into your home?
    Will fuck off, again.
  12. #312
    Quote Originally Posted by speedog View Post
    Telus can on the residential side.
    - - - Updated - - -
    I'll look into this thanks, probably going to turf cable so it wont be otherwise used for anything.
    I like me my hardlines.
  13. #313
    Why would that matter? You can easily use it on internal traffic.
  14. #314
    N/A
    You do have a point there.
  15. #315
    Sep 2005
    2011 lexus is250 awd
    These are theoretical numbers, do you know anyone using this that can give feedback on what they are actually getting?
  16. #316
    Yea im not very confident about even fast ethernet through our 40 year old, coax cable.
  17. #317
    Sep 2012
    I'll check mine when I get home. Very high throughput and low latency though. Can't remember exact numbers.
  18. #318
    I've used MoCA 1.0, 100mbps no problems. Reviews of MoCa 2.5 is legit full 1gbps with 2-3ms latency.
  19. #319
    Sep 2005
    @suntan
    If this is anywhere above 300Mbps I would be satisfied
  20. #320
    Jan 2006
    Axis powers
    Looking to upgrade my wifi during black friday, anyone know of any potential deals? I'd rather not require a device that needs to be licensed
    Sig nuked by mod.
  1. Finally upgraded to a dual band DD-WRT router
    By WhippWhapp in forum Computers, Consoles, and other Electronics
    Latest Threads: 04-04-2017, 10:49 AM
  2. FS: HP Procurve 1800-24G managed network switch
    By Smokem in forum Computer Hardware & Peripherals
    Latest Threads: 03-14-2012, 06:09 PM
  3. Managed Funds
    By cidley69 in forum Real Estate / Finance
    Latest Threads: 02-23-2012, 08:44 AM
  4. Something, something, something, Dark side
    By Tik-Tok in forum Entertainment
    Latest Threads: 12-27-2009, 08:15 PM
  5. FS: Netgear FSM726S L2 managed Switch
    By 02WhiteWs6 in forum Computer Hardware & Peripherals
    Latest Threads: 11-16-2007, 05:03 PM
