You could use any smart thermostat you like if you put one of these in the loopThis quote is hidden because you are ignoring this member. Show Quote
https://www.aartech.ca/rc840t-120-au...ansformer.html
Picked up the 'free' Honeywell Lyric T5 from Best Buy and tomorrow night's project will be to pull in a new cable.This quote is hidden because you are ignoring this member. Show Quote
Will fuck off, again.
Well the Lyric T5 is in and working. Pulling in a new cable was a bit of a pain in the ass in a fully finished 1955 bungalow and then having to change the furnace wiring setup because we were just a two wire system before but all is good now. Pretty cool to be able to access it from my phone, I think even my technology challenged wife will use the app on her phone.
if you are missing a C wire, you can use an add-a-wire kit so you don't have to pull a wire. I did this on my main floor nest and haven't had any battery issues. Actually have a spare since I bought 2 but found an unused wire for my second floor thermostat that I just moved to the C
https://smartthermostatguide.com/c-w...dapter-review/
Did this Ikea hack for a mounting plate for the nest as well. $6.99 Aptitlig chopping board, routed out so that the nest sits recessed
heloc that shit
That looks pretty nice. When the ac guys installed mine they put on that POS plastic plate and then just screw it into drywall so I could just pull it out from the wall when trying to pull the face off. I ended up going for the naked look after patching the wall and mounting it to the stud.This quote is hidden because you are ignoring this member. Show Quote
No stud for mine, drywall holds it just fine?This quote is hidden because you are ignoring this member. Show Quote
I did have to repair my drywall when i installed Nest to make the hole smaller. Honestly i think my builder just used a hammer to make the hole the first time around...
The plastic plate is garbage though for sure...
Screws it came with were garbage and not holding into the drywall. Just free spinning and then if you tugged on it, it would come out. Hole was so big in my wall I had to use mud instead of spackle. My original install was just poor I think and then I fixed it when I replaced it with a Gen 3 as I was able to return the gen 2 they gave me.This quote is hidden because you are ignoring this member. Show Quote
I don't think the add-a-wire kit is something one can wander into a Home Depot and get locally, I wanted the thing up and working and pulling in a new cable was quicker than waiting for a kit to arrive from somewhere else.This quote is hidden because you are ignoring this member. Show Quote
Did you use the drywall anchors it came with? It should have prevented that 100%.This quote is hidden because you are ignoring this member. Show Quote
I'm running about half of the eleven Nest3 I have in the house without a C wire, and their charging hack seems to work fine.
I didn't do the original install. It was done by a qualified installer who was also supposed to wire in the humidifier but couldn't figure it out in two trips.This quote is hidden because you are ignoring this member. Show Quote
ah. I had the same problem, I didn't have enough wires running up from the furnace room to the controls. Didn't want to start cutting holes in a finished basement. Why can't they have wireless modules/controls.....This quote is hidden because you are ignoring this member. Show Quote
I think they coudln't wire it as there was only one wire available and they don't know relays exist. Still need to do it myself but keep forgetting about it.This quote is hidden because you are ignoring this member. Show Quote
That Lyric thermostat is awesome. We installed one at my parents' house and just added the C wire. Works wonders and provides outside temperature too, which is nice.
You can sort of do that with Ecobee. Install it in the furnace room, and just have remote temp/occupancy sensors through the house. The drawback would be no physical access for controls and you would have to use the app, but in reality we haven't touched our temperature settings since we installed it.This quote is hidden because you are ignoring this member. Show Quote
Of course that doesn't work with the Nest, as it relies on usage and temperature changes that you would make to learn the patterns. That and the furnace room temperature is probably way off than what you actually need to reference off of for triggering heat/cool.
Hello and welcome back to the nest thread.
Nest Hello comes out this week to solve all the issues with ring being terrible.
https://nest.com/ca/doorbell/nest-hello/overview/
Nest has created temperature sensors to solve all of rage2s gripes as well
Someone found them on reddit. Not sure when they will be releasing though as their page was soon after taken down (homedepot US)
https://imgur.com/a/NOObW
Battery powered w/ 2 year battery life (Cell batteries) so place wherever. Works with Nest 3 or Nest E and it was something like 8 you could use at once.
No new info on the security system yet, but it would be stupid expensive here anyways.
Ffs I don’t want to buy a new nest just to use temp sensors...
Gen2 here.
Their security system is pretty underwhelming anyways.
Pretty interested in a Hello though.
I don't need to buy a new nest and a new doorbell to get what I already have either.This quote is hidden because you are ignoring this member. Show Quote
A little too late Google.
I can't remember what the spec sheet said as it is down now, but the only thing the gen 2 wouldn't have is bluetooth. It does have zigbee in all generations so I don't fully understand the decision as multi-hundred dollar items with actual installation aren't likely replaced often.This quote is hidden because you are ignoring this member. Show Quote
I am hoping my hello comes this week so when I don't ever answer the door, I can know who was there.
Nest also now has a $5/month $50/year camera option for 5 days of storage. This is much better than $10/$100 for 10 day as I don't need that much time. Additional cameras are $30 (40% off) a year where as on the 10 day plan they were $50 (50% off).
I have not tried any sensors myself as I have been assuming the snail called nest would eventually release one.
