New job, can work as temp employee or contractor, which better? - Page 3 - Beyond.ca - Car Forums
Page 3 of 5 FirstFirst ... 2 3 4 ... LastLast
Results 41 to 60 of 93
Thread: New job, can work as temp employee or contractor, which better?
  1. #41
    Sep 2016
    Calgary, Ab
    2021 Zonda CRV
    Just to add... If you go down the contractor route. You also have to factor in insurance for yourself as a self employed person, i.e liability as a example. That will add to your expenses.
  2. #42
    Doesent the OP need to pay GST as well on services rendered?
  3. #43
    Sep 2018
    Edmonton, Alberta
    Quote Originally Posted by Xtrema View Post
    OP only get paid $5/hr more as contractor. 160 hr month = $800 more per month.
    You get paid $1800/mth more as contractor.
    On top, OP get stats and vac pay. Stats alone is already $5200/year as Mitsu pointed out. Effectively reduce the differential from $5/hr to $2.50/hr.
    I think at $65/hr, I don't think OP will hit any of the new limits set by the Liberals. But at that low differential, it's not worth it to incorporate unless OP already set one up. I think doctors and SMB that clears over $150K revenue per year are the one being targeted by the Liberals.
    I hope you have talked with your tax accountant in the last year or so after the rule change.
    There is a reason why the doctors are pissed:
    https://obj.ca/article/new-tax-rules...ian-physicians
    I realize this is foreign material for most of you. But the difference in pay is NOT 5$/hr. It's not what you make that is important, it is what you take home.
    Employee
    Hourly 60$ + 4% vac pay=$62.50/hr minus effective tax rate and all deductions(40%, more like 42%, but we can call it 40), gives you a total take home hourly pay of $37.50 x 160hours/month = $6000
    Contract
    Hourly 65$ minus effective tax rate including average write offs for year end(25%) gives you total take home hourly pay of $48.75 x 160hours/month = $7800
    Yes I used my personal and very normal average situation to calculate those numbers. The OP's may very well be different.
    - - - Updated - - -
    Yes and no. As a contractor he would be invoicing 5% above the 65$/hr for GST. And then just handing that 5% over to the government. It's a moot point basically.
  4. #44
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Yeah, so marth
  5. #45
    Bicycle
    Quote Originally Posted by ercchry View Post
    Yeah, so marth
    lol, so true. $65/hr for 2000hr = $130K. He doesn't even break into the 2nd bracket of AB tax or 4th bracket of Federal one. He's effective take home is about 71% after AB tax/Fed tax/CPP/EI.
    29%, not 42%.
    source:
    https://simpletax.ca/calculator
    Employee
    Contract
    First of all, it's $65 vs $70
    But keeping with what you got there using the proper rate:
    $60+4% = $62.50 * 71% = 44.38 *160 = $7100.
    Again, you charges more, so you'll have income that will be in higher bracket and in higher tax rate. So your formula works (to a degree) for someone that charges more than $70/hr. Not at OP's rate.
    Also, keeping money in corp has less of an advantage now. So that removes another reason.
  6. #46
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    29%, not 42%.
    source:
    Not to mention that his deductions are effectively subsidized, since if he was inc he would have to pay employee and employer portions
  7. #47
    Employee
    Contract
    How are you getting 42% tax? You know it's tiered right?
  8. #48
    Bicycle
    To give him benefit of the doubt, he probably have significant portion that clears well over $160K per year, so he may have significant portion in that bracket.
  9. #49
    Ah, the ol' humble-brag approach
  10. #50
    Sep 2018
    Edmonton, Alberta
    So you guys haven't contracted. You've apparently never had a job either, or if you have you haven't cared to examine your gross vs net pay difference. And have no understanding of the difference between tax rate and total deductions. That's cool though, I'm sure you're all more knowledgeable than anyone who has done both or any certified accountants. . Good luck to OP.
  11. #51
    Bicycle
    I think a lot of people here have done it and currently doing it and we are telling you as of 2019, there is very little incentive to contract if you don't clear over $130K per year especially with a single customer or unless you have a very creative expense scheme that CRA has not caught on yet.
    There are a lot of people who plays the CRA audit roulette too.
  12. #52
    Oct 2003
    ute
    Three things to never do when you walk into a room full of people:
    1. Assume you are the best looking
    2. Assume you know more than everyone else/ are smartest
    3. Assume you are the richest
  13. #53
    Sep 2018
    Edmonton, Alberta
    Some good information here fellas. Take heed.
  14. #54
    Sep 2012
    https://www.ey.com/ca/en/services/ta...9-personal-tax
    Do $160K.
    Even adding CPP/EI, you'll get nowhere near 42% average tax rate.
    Misterman is the new Gestalt. Now with spellchecker!
  15. #55
    Apr 2004
    Apr 2004
    Do $160K.
    that's a good calculator. If you type in 130k ($65/hr), it will show your marginal tax rate as 36% and the ineligible dividends marginal tax rate at 28.5%. I see that as showing the tax advantage in AB between employee->corp is < 8%
  17. #57
    Bicycle
    You won't even hit an average of 42% in AB until you hit around $430K.
  18. #58
    Sep 2012
    Yeah but then your corp pays taxes, which makes up the difference.
  19. #59
    Jul 2011
    Ford F150
    +30% pay over and above employee rate is the break even for going contracting in many fields.
    $5 on $65 is a joke, take the temp employee option as fast as you can.
  20. #60
    Jan 2017
    Summer car or work truck
    If he is talking about all deductions, I can see 42% being accurate. If I use my gross number and multiply it by 42% I get close to my net. I make no where near 430k. I do pay a small portion of my medical coverage though.
    Edit.....besides the point. *Temp. employee for the win
  1. Full time employee to contractor
    By Manhattan in forum Careers
    Latest Threads: 09-15-2013, 09:39 AM
  2. 3 month temp job - use as work ref?
    By copynpaste in forum Careers
    Latest Threads: 05-07-2010, 10:22 PM
  3. contractor vs. employee
    By fraction in forum Real Estate / Finance
    Latest Threads: 05-07-2010, 06:44 PM
  4. Haterz Better Get A Better Job!
    By mr.loco in forum Cars, Bikes, Machines
    Latest Threads: 01-22-2006, 10:05 PM
  5. WTB: Oil temp and Water temp gauges
    By jaylo in forum Automotive Parts [Engine Electronics]
    Latest Threads: 07-24-2005, 06:40 PM
