They do, but pretty much just rear tires. And even then, they run them all year round. They are just a heavy lug tread.This quote is hidden because you are ignoring this member. Show Quote
They scratch garage floors if you turn your wheels while parking, and they can be noisy as fuck depending on your vehicle. They barely cost anything, I think the last time I had studs installed (in a studdable tire), it was $60 for all 4. They also reduce fun when you purposefully want to ice drift.This quote is hidden because you are ignoring this member. Show Quote
They're overkill 99.999% of the time, but when realize you really could have used them it's likely because you just hit the car in front of you while on a sheet of ice (thanks to Calgary's wonderful thaw/freeze cycle). Not that I've done that...
I was that .001% on the second day of this storm. I got into a slide going onto an offramp and 100% i wouldve hit the curb if it weren't for the studs.This quote is hidden because you are ignoring this member. Show Quote
Some peoples manhood is closely tied to their insistence on using substandard tires for the conditions.This quote is hidden because you are ignoring this member. Show Quote
Or something to that effect.
"antilock brakes reduce braking performance"
-HighTempGuy
Depends on the vehicle. I can manually out-stop most ABS systems 99% of the time.This quote is hidden because you are ignoring this member. Show Quote
MAGA = My Ass Got Arrested.
Beware the passive aggressive Mean Girls. Vengie, Killramos, Penismightier, buster, jrscoolude, etc who bully others into their circle jerk opinion, serially negging you, while claiming they ignore you and don't obsess over you.
PSA. High school is not a popularity contest little girls
Meanwhile: 80F in New York.
Cocoa $11,000 per tonne.
Weren’t you an engineer in a previous life? Didn’t know large vehicles were immune to the laws of physicsThis quote is hidden because you are ignoring this member. Show Quote
(Object in motion… large mass… etc)
Yes, but also more weight means higher coefficient of friction. There's also probably some consequential aspect of it being able to compress/cut through the snow better as well (both of these are exemplified by rally cars using super narrow tires for winter/ice runs - smaller contact patch has the same effect as more weight).This quote is hidden because you are ignoring this member. Show Quote
Most of this is actually high school physics IIRC. There was a significant overlap between that and first year eng physics.
This is why 18 wheelers stop on a dime in winter, and why motorcycles are just as effective.This quote is hidden because you are ignoring this member. Show Quote
Yes, but all is meaningless when the coefficient of friction is 0 when it cuts through to pure ice without the studs (that your narrow rally car example would have for icy conditions) and the thing does not stop, which is the factor that every single 4x4 in the ditch seems to forget
Well yeah, more mass takes more time/distance to stop. I agreed with you the first time. The point of contention is to the extent which "all season tires" benefit from having more weight on them.This quote is hidden because you are ignoring this member. Show Quote
I'm not that type of engineer, but I know enough to say we're both grossly oversimplifying this. Furthermore since we're each talking about two separate variables of a multivariable equation, we can actually both be right.
Fair, as long at coupe’s almost impossible to quantify, simplistic response continues to be meaningless
Thread split to Grade-10 augments about mú, the coefficient of static friction, please.
Then close the door and lock it on YoLoBeRmEr right away.
*But why isn't it the dynamic coefficient since car is moving?!??
*Kaboom Mind Blown
Weight is good
-car guys
The plane will take off from the treadmill.
The best vehicle I’ve ever driven in winter was the 96 ford windstar on blizzak mz03. It was amazing.
Run bald tires. ABS won't turn on. Solved!This quote is hidden because you are ignoring this member. Show Quote
- - - Updated - - -
Also car guys.This quote is hidden because you are ignoring this member. Show Quote
Sandbags in the trunk + RWD = stop on a dime every time. What could go wrong?
