ok, so i took apart my rims and painted the center section black, and while i had them apart i realized they were 3 peice rims, the polished lip was a seperate peice from the rim itself. While i was taking the studs out of the rims, the seal between the lip and the rim popped from the pressure, letting the air out...Now me being an idiot i had the rims painted and all back together before i thought about whether or not i should use a sealant between the rim and lip...i was only dealing with the center section, i never pulled the lip off of the rim so it never occured to me
Long story short my rims arent doing a very good job of holding air now....so i get to undo all 160 studs, fix the problem, and re tighten all 160 studs
My question is what should i use as a sealant between the rim and lip?
Thanks in advance
