Ford Trucks Thread WAS:EcoBoost Thread - Page 98 - Beyond.ca - Car Forums
Page 98 of 262 FirstFirst ... 88 97 98 99 108 ... LastLast
Results 1,941 to 1,960 of 5234
Thread: Ford Trucks Thread WAS:EcoBoost Thread
  1. #1941
    Ford, Acura
    Quote Originally Posted by bigboom View Post
    My truck makes both of those sounds. Haven't had any issues come out of it other than the sounds though.
    I can't speak to 94Boosted posted but the cold start rattle is a symptom of the timing chain stretching and slapping against the side of the case. This will eventually cause you to wear through the case, damage the chain, and cause a pile of timing issues if left unattended. I don't know how long any of that takes but once you hear that horrible rattle noise you know its pretty bad.
    I'm generally cute.
  2. #1942
    Cayman
    Quote Originally Posted by Proyecto2000 View Post
    Have any of you guys experienced a vibrating gas pedal?
    I have an 18 with 31k km now and for the last week when i am driving under 20km/hr usually during rush hour on 5th ave my gas pedal vibrates so much so that my entire right leg vibrates. If i press on the gas and go faster it stops.
    On the cold start rattle; mine has done it a few times but it is not constant. So far it has rattled on 3 out of 8 starts this week for about 20 seconds and the rattle dies down.
    I am back from the dealership with some results:
    Vibrating gas pedal was fixed by Ford replacing both front wheel bearings which they said were worn out as well as the actuators.
    Cold start rattle they need to order parts to replace the timing chain and cam phasers so be back in 3 weeks.
    The annoying TPMS issue that has haunted me for 6 months is still not resolved as they cant figure it out and they are waiting on the Ford help desk to give them more ideas. They have replaced the sensors, rotated tires, updated software and still the front drivers side is not detected by the computer.
    also on the waiting for the block heater cord.
  3. #1943
    Mars
    A car, a truck, and a bike
    No those all sound terrible, thats not at all the sound I'm talking about. That should stop, when I hear it its very brief
    https://youtu.be/okExmvZCWu0?t=37
  4. #1944
    Quote Originally Posted by schurchill39 View Post
    Even at 30,000k the timing chain has stretched that much? Well good thing it's only lease till next August!
  5. #1945
    rs4, ram, 675f3
    I have a 2015 navigator and it will pull hard left on startup, for a couple min. It goes away all tires are ok it seems to be a mechanical issue with something not releasing pressure if that makes sense. Like I said it goes away fairly quick, but happened to the wife again today so it’s time to start digging into it.
  6. #1946
    Jan 2006
    GR Supra MT, MK8 Golf R
    The "cold start rattle" that has the TSB out is more of a rattle/knocking that lasts maybe 2-3 seconds right as the engine turns over. Sounds like a chain slapping metal. To capture mine I've always had to set my phone up before turning the truck on because it doesn't last very long at all. More like this video, mine sounded like his very first one "May 21st 2017"
    Interesting, I take it the TSB is specific to Gen 1 EB motors?
    If the timing chain is in fact stretched and slapping against the case would that not also continue after the engine was up to temp?
  7. #1947
    Ford, Acura
    Quote Originally Posted by 94boosted View Post
    It goes away as you build oil pressure and the tensioner take up the slack on the chain.
    I'm generally cute.
  8. #1948
    CGY
    Cayman, F150, Crosstour
    My 2011 (G1 EB) had the timing chain stretch (~3k repair ), The rattle would only happen when cold at startup for a few seconds.
  9. #1949
    Edmonton, Alberta
    Exercised the truck a bit. Used the ditch to get the ramps a little more level (car didn't have a functional clutch and I don't have a winch). Did absolutely fantastic getting out. 4hi and locker engaged and it crawled out. It was a little soupy at the bottom, so I'm quite glad I had the locker.
  10. #1950
    Oct 2006
    Parked in Baygirl's garage.
    '21 F150 PowerBoost
    New 2021 F150 interior redesign...
    Not sure if I am a fan or not. Seems like they are trying to make the interior more car like...Kinda turns me off, it's a truck, I want the interior to be a little more rugged, yet comfortable.
    NVM thats a 2020 Explorer...
    Boosted life tip #329
    Girlfriends cost money
    Turbos cost money
    Both make whining noises
    Make the smart choice.
    Originally posted by Mibz
  11. #1951
    Mars
    I don't even think its the explorer, that looks like an escape with those parallel hood lines. Or an ecosport
  12. #1952
    You want a "trucky" interior you get the low trim level with the bench seat and a column shift and it'll be plenty trucky.
  13. #1953
    Feb 2006
    CEF4
    Ralli Machine
    Someone left their iPad on the dash in the photo I see
    Cos...
  14. #1954
    I sat in one this morning. It's a nice interior.
  15. #1955
    Jul 2007
    the upside-down
    Edge Sport, F-150 EcoBoost
    Quote Originally Posted by ShermanEF9 View Post
    Nice! Those lockers come in handy.
    freshprince
    -Jan 2006-
  16. #1956
    Edmonton, Alberta
    Quote Originally Posted by freshprince1 View Post
    I would argue its the best addition ford made to the trucks.
  17. #1957
    Jun 2014
    Quote Originally Posted by TurboMedic View Post
    Yeah that hood looks very small
    Mark my words, hell be trading this in on the new truck to get the cushier interior lol Im all for these nice interiors though, my truck is not a work truck so bring on the goodies
    the 2021?
    and I did not have the only say in the matter (most people just want it done ASAP and don't care about quality).
    If anything we made a better decision because we had a consensus and were all on the same page.
  18. #1958
    Aug 2008
    Medicine Hat
Size:  52.0 KBI am loving the interior on my new work truck, seatbelts are a nice touch!
  19. #1959
    Calgary,AB
    For sure is, pic was taken from Car And Driver
    https://www.caranddriver.com/news/a2...chscreen-2020/
  20. #1960
    Why does ford leave the gear selector in the console? Do you prefer it? Moving it to the dash frees up so much console space.
  1. Replies: 32
    Latest Threads: 08-01-2014, 05:24 AM
  2. Replies: 24
    Latest Threads: 01-10-2014, 07:08 PM
  3. 2013 Ford F150 /w Ecoboost
    By puya.ro in forum General Car/Bike Talk
    Latest Threads: 07-05-2012, 10:31 AM
  4. FS: 2010 Black Ford Flex LTD AWD Ecoboost
    By lint in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 05-22-2012, 10:14 AM
  5. The crazy Ford Ecoboost 3.5L V6 test
    By Cos in forum General Car/Bike Talk
    Latest Threads: 02-05-2011, 12:33 AM
